How do I know if I have the brake vacuum pump kit intalled????
Old 02-14-2013 | 08:11 PM
badassbowtie's Avatar
I purchased a trifecta tune and got this question in an email???I bought the car used so I'm not sure if I would have it or not...
"Do you know if your HHR has the brake vacuum pump kit installed?
We'll need to know in order to write the tune. If you are not sure, you might be able to find out through your Chevrolet dealer."
Old 02-14-2013 | 09:23 PM
is this the pump that was to be installed for the GMS1 problem( and various other problems)???
sorry for the blur
Old 02-14-2013 | 10:47 PM
I would love to answer you but I really can't make out your picture. What angle is that taken from?
Old 02-15-2013 | 09:08 AM
I was laying underneath my car...my head under the engine, my waist under the front bumper....I couldn't get a good picture in the dark...
I googled a part number I found and it was the mounting bracket surrounding the pump thing circled in the picture. It said power brake boost from gm parts website
Old 02-15-2013 | 09:36 AM
JerseyJames's Avatar
Post Vacuum pump kit
copied this from a "problems" board
" HHR SS TURBO Brake problem - MARCH 28, 2009
The problem is low vacuum in the brake booster at initial start-up when the engine is cold. Cold meaning has been sitting for 4 or more hours. It doesn't necessarily mean cold ambient temperature.
If you start the vehicle and the brake pedal is very hard when applying the condition is happening. After 30 seconds or so the brakes go back to normal because the vacuum is built up from the engine running. After that you would not experience it again until the vehicle has been sitting for an extended time.
The issue is addressed in TSB 09-05-22-001, which basically adds a vacuum pump into the system. "
appears that the kit was a fix for a problem that appeared after the vehicle (auto trans) was on the road, so if you bought the SS used, could be on there. use TSB 09-05-22-001 in the search box on here for additional info. wonder if this is what your trifecta tune is concerened about. hope this helps..
Originally Posted by WS6
Had the brake fix installed yesterday. Took them six hours. The work order shows the following:
Installed 11518257: CLIP (04931-BPCK) Qty: 1
Installed 11570082: BOLT (08900-BOPCKT) Qty: 2
Installed 11588738: BOLT (08900-BOPCKT) Qty: 1
Installed 12177236: RELAY (09778-BOPCKT) Qty: 1
Installed 15319476: FUSE (08965-BOPCKT) Qty: 1
Installed 19115602: CONNECTOR (04820-PCKT) Qty: 1
Installed 20804130: PUMP (04895-PCKT) Qty: 1
Installed 20815216: BRACKET (04805-C) Qty: 1
Installed 20817629: HOSE (04931-C) Qty: 1
Installed 20817688: INSULATOR (04805-C) Qty: 1
Installed 3530297: NUT_AIR I (08917-BOPCKT) Qty: 2
Installed 88988583 CONNECTOR (03682-BPCKT) Qty: 1
INSTALLED VACUUM PUMP RETROFIT KIT, REPROGRAM
BULLETIN 09052201A
Started the car this morning and still took about 2 mins. to build up 20lbs. vacumn.
Originally Posted by bigjacksauto
HHR SS QC
do you have the dealer installed vacuum pump bolted to the bottom of the oil pan and it only runs for a few seconds or are you referring ...(yada,yada,yada(me)
and a reply about when the pump is supposed to operate..
Originally Posted by ChevyMgr
I believe it runs as soon as the key is on. You can hear it at the front of the vehicle. It is by the oil pan down low.
(.... @ ChevyMgr)
Old 02-15-2013 | 09:57 AM
ChevyMgr's Avatar
If that is mounted next to the oil pan, that's it. It should come on when cold started.
Old 02-15-2013 | 11:16 AM
Thanks for the info.... I guess my question is, is the pump that I have pictured, definitely the pump that is from the service bulletin? Is there another pump there that gets replaced, or is it more of an accessory?
Thanks again for the info....I'm trying to get tuned this weekend!
Old 02-15-2013 | 11:39 AM
ChevyMgr's Avatar
Only way to answer that is to see a better pic.
Old 02-15-2013 | 02:46 PM
Here are some better pictures....all of them are from laying on the ground and looking up point of view
Old 02-15-2013 | 03:22 PM
ChevyMgr's Avatar
Not enough arrows.
Quick Reply: How do I know if I have the brake vacuum pump kit intalled????
