how do u reset the "oil life percentage"
Old 11-29-2008 | 11:21 AM
soccerjunky's Avatar
anyone?
also on a side note there is a shortage of mobil 1 untill april.. apparantly hurricane ike damaged a plant where the synthetic additives are introduced into the oil
Old 11-29-2008 | 11:45 AM
SindyDix's Avatar
From the owners manual:
After changing the engine oil, the system must be reset as follows:
1. Turn the ignition to RUN, with the engine off.
2. Press the information and reset buttons on the DIC at the same time to enter the personalization menu.
3. Press the information button to scroll through the available personalization menu modes until the DIC display shows OIL-LIFE RESET.
4. Press and hold the reset button until the DIC display shows ACKNOWLEDGED. This will tell you the system has been reset.
5. Turn the key to LOCK.
dandhcomputers's Avatar
I live down the road from moble and they are saying that the plant will be up and running in about 6 month.when all the supplys are out there will not be any moble 1 left
Old 11-29-2008 | 11:57 AM
xzombiex66's Avatar
Turn the Key on but do not start the car, press the gas pedal i think 5 times within like 3 or 4 seconds turn car off, then turn car back on . it will be reset.
Old 11-29-2008 | 04:41 PM
08blackHHRSS's Avatar
Think it's : Key on/gas pedal depressed to the floor (full/quick motion)3 times then the DIC will prob say "oil life reset" a lil after.
Think that is the standard way to do it on most GM's(if you don't have a full-on DIC )
Old 11-29-2008 | 06:11 PM
halfpanel08's Avatar
x2
Old 11-29-2008 | 07:37 PM
stranger's Avatar
Originally Posted by soccerjunky
anyone?
Just use Amsoil!!!!!!!!!!!!! www.amsoil.com if ya don't have a dealer near you. Use my zo if you want to it's ZO #1195231.
Old 11-29-2008 | 10:53 PM
This also works
Press and hold the reset and information buttons for about 3 seconds until the "oil life reset" appears in the display ...release the buttons and then press the reset button one more time and "acknowledged" will appear in the display and your done
this is all done with engine off / ignition on position
Old 11-30-2008 | 12:25 AM
ivtech's Avatar
Pushing the gas pedal method does not work on the SS.
Originally Posted by ChevyMgr
Document ID: 2200465
#PIP4511: Unable To Reset The Engine Oil Life System Using The Accelerator Pedal - keywords DIC ECM EOL engine inop inoperative intermittent life lof lnf maintenance message monitor oil OLM pedal performance - (Oct 16, 2008)
Subject: Unable to Reset the Engine Oil Life System Using the Accelerator Pedal
Models: 2008-2009 Chevrolet HHR SS With Engine RPO LNF ONLY
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A technician may report that the Engine Oil Life (EOL) will not reset.
Recommendation/Instructions:
Engineering has determined that the ECM for the 2008-09 HHR SS does not support the use of the accelerator pedal for the Engine Oil Life System reset procedure. This is listed incorrectly in eSI and the Owners Manuals of this vehicle; and is in the process of being changed.
Technicians should be advised to use the DIC procedure or Tech2 to perform the EOL reset.
Old 11-30-2008 | 12:34 AM
Uma's Avatar
Uma
Do as Sindy says, that is the way you are supposed to do it, works everytime, go figure. Or read the manual. todd (Uma)
