How to get the air out of the cooling system
Old 08-09-2017 | 06:49 AM
shojay92's Avatar
Hey guys I'm the guy with a red 2009 Chevy HHR SS. I love the car but I can't drive it because it needs a new engine. It is going into the repair shop soon for a new installation. I am buying a zzperformance LDK long block. I already know that it is tricky to get the air out of the cooling system for these Ecotec engines. I do not want the repair shop to mess up my brand new engine so my question is, what do I tell the mechanic when I drop my car off? Do I ask him how are you planning on getting the air out of my cooling system? Or do I tell him to loosen the nut above the water pump housing to get the air out? Could somebody that knows what needs to be done, please let me know. That would be greatly appreciated.
Old 08-09-2017 | 09:07 AM
Ensure they jack up the front passengers side , then fill the cooling system .
Run the engine till warm, let it cool off then check the Dexcool at the rad hose cap.
Take it off the jack stand and drive the car for 10 minutes, jack up the passenger side or park it with the front bumper higher than the rear. Let it cool off and recheck the Dexcool and top off if required!
Recheck again after a day or two.
Old 08-09-2017 | 09:25 AM
JAN67's Avatar
To highlight the final step from Old Blue's post, recheck after a day or two. I see that noted in pretty much every post I've seen on this subject!
Old 08-09-2017 | 09:56 AM
Yep, what OB said. The issue is that the filler cap is not the highest point of the system. Raising the front of the vehicle makes the cap higher.
I had a heck of a time getting the air out on mine. Burped it for several days, thought I had it. But then a trip to Vegas in the summer had it running just over 220*. Not high enough to cause damage, but high enough to make me nervous.
That was about 300 miles into a 2000 mile trip, it was all worked out about halfway through.
Ideally, I would check every morning for 2 weeks.
Old 08-09-2017 | 10:13 AM
And run the heater at full heat a couple of times to get water Dexcool thru the heater core.
Did I mention use Dexcool, and a 180 degree AC Delco thermostat P/N 131-158, our friends at CARiD have it
https://www.carid.com/acdelco/gm-ori...n-131-158.html
Old 08-09-2017 | 11:08 AM
Of course, they may have a coolant installation machine that sucks the air out. They exist and are the way "the book" says to do it.
Old 08-09-2017 | 01:07 PM
Mine is getting changed next week... It's ten year old coolant. (gotta be some kind of record)
Old 08-09-2017 | 03:27 PM
It only has a 5 year life, I'd change the thermostat also!
Old 08-09-2017 | 04:35 PM
Originally Posted by Oldblue
It only has a 5 year life, .....
Yeah.... I know.
Old 08-09-2017 | 04:47 PM
Buy a lottery ticket, before your luck runs out!
Trex08
11-19-2016 10:35 PM
RICK167448
Maintenance and Upkeep
7
01-21-2011 02:14 AM
skyeglen
04-26-2009 08:51 AM
SSROADSTER
06-07-2008 05:14 PM
Quick Reply: How to get the air out of the cooling system
