how will it sound if i cut out the resonator?
Old 10-03-2011 | 12:39 PM
20HHRSS08's Avatar
just get you a 3" turbo back set up .. i have the ZZP catless DP and ZZP 3'' to magnaflor muffler at rear with 4" tip .. sounds good .. does drone on highway though
Old 10-03-2011 | 12:47 PM
ChevyGuySS's Avatar
im saving up for the catless DP and im looking around for a tip now, i hate the one that is on it, it does a little but just turn up the radio, ill probably end up getting the DP when i dont have to commute so far on the highway just incase it does drone
Old 10-03-2011 | 08:06 PM
foolmoon_design's Avatar
The drone isn't that bad... if the radio is on. really its not that bad. When you get the cat-less DP be sure to quickly re-tune or buy a code reaader/clearer. the O2 will read way too much, another clue the motor overcompensates and you will notice a slight 5-10 degrees rise in engine temp for that ignition cycle, on your next cycle you will have a check-engine with P2096 post-catlyast something or another showing one to two times on a scanner. depending on how you drive you could see a code everyday or none for a few weeks.
Just to let you know what your getting into before putting on a DP, even the ones that come with a de-fouler welded in will still throw a code once in a while. FYI
Old 10-04-2011 | 03:04 AM
1Panel2NV's Avatar
Changing downpipes will not affect your coolant temperature.
Old 10-04-2011 | 05:38 AM
sorry not your coolant, was tired when posting. I meant the outgoing gas that the O2 senses, its temps are slightly higher.
Old 10-04-2011 | 04:12 PM
1Panel2NV's Avatar
The oxygen sensor doesn't read temperature either.
Old 10-05-2011 | 08:56 AM
No panel, it doesn't but I do, and when I don't have something I want to monitor, I go out and get it. Like a hand-held temp reader. Jesus, does the car have to tell everything? Btw, when it throws P2096, it affect/effects the entire paramaters of the engine. An don't say it doesn't look at a data-log it throws the code, retards the timing, and leans the fuel... thus causing some temp increase in the entire engine. coolant and exhaust both go-up.
Old 10-05-2011 | 05:53 PM
1Panel2NV's Avatar
Calm down friend-o
The rear O2 sensor is only there to monitor how well the catalytic converter is working. All of the Lambda readings come from the wideband sensor in the O2 housing.
CHRISCARGUY
2.0L Performance Tech
14
06-10-2014 10:34 AM
swerv0428
Mods - Engine/Exhaust
32
07-28-2012 10:59 AM
capp002
09-20-2011 06:25 PM
Geronimo38
06-23-2011 05:44 PM
