Idle Ticking
Old 02-21-2012, 01:06 AM
RBodeman's Avatar
Idle Ticking
My 2010 HHR SS does a great deal of ticking while idling. Dont really notice it much sitting in the car but lift the hood and OH MY.
Tick tick tick.
Is this all normal or is there something wrong with the thing?
My old 1991 Mazda MXG GT turbo did lots of ticking but not this loud.
RBodeman is offline
Old 02-21-2012, 01:10 AM
What you are hearing is the high pressure direct injection fuel system, one of the characteristics of Direct Injection engines is a "ticking" sound made by the fuel injectors.
Every DI engine I've heard does that to some degree, the engine in my wife's new Fiat 500C ticks away happily like a sewing machine at idle.
843de is offline
Old 02-21-2012, 01:17 AM
Breadfan's Avatar
So if it's ticking before you start it, then you might worry.
Breadfan is offline
Old 02-21-2012, 01:22 AM
Yeah, ticking before you start it might leave you wondering who you "ticked" off for the lack of a better term, maybe a quick call to the bomb squad might be in order if that's happening.
843de is offline
Old 02-21-2012, 06:14 AM
08SSREDHHR's Avatar
Ecotec Tick+direct injection.
08SSREDHHR is offline
Old 02-21-2012, 09:23 AM
If I was a high pressure fuel pump making 1700-1800 psi at start up I would make noises too!!!
firemangeorge is offline
Old 02-21-2012, 05:41 PM
hyperv6's Avatar
Yes the tick is present in all new DI engines. Also if you see a black puff of smoke and soot on the tail pipe that is also normal as they puff at start up.
Yes even with the puff these are cleaner running engines.
The later SS have a insulated cover on the pump that helps. The early 09 and the 08 SS lack this cover and if you are under warranty they have a TSB to add it at no charge.
hyperv6 is offline
Old 02-21-2012, 06:16 PM
bigjacksauto's Avatar
So are the 2.2 and 2.4 motors direct. Injection as well?
Are they prone to the ticking and puffing as well
bigjacksauto is offline
Old 02-21-2012, 06:39 PM
foolmoon_design's Avatar
[QUOTE=hyperv6;619840]
Until you rip the CATS off!
foolmoon_design is offline
Old 02-21-2012, 09:45 PM
The 2.2 and 2.4 are multiport injected engines, "old fashioned" tech these days, but DI will be on the "new" 2.5 Ecotec coming in the 2013 Malibu and other models.
So no ticking or puffing of carbon at startup, a happy 2.2 or 2.4 will idle with a gentle mechanical purr, they are actually quite pleasant to listen to when you're under the hood.
843de is offline
Quick Reply: Idle Ticking
