Installing SS Instrument Cluster In A LT
Old 06-17-2015 | 12:18 AM
Hiperguy's Avatar
Has anyone installed or any knowledge installing a SS Cluster in a LT with System/Dash Infor.Does the SS Cluster have to be reset Mileage or anything else to bring it up and everything working properly?? Or will the computer automatically sense everything includeing the mileage?If possible can you E-Mail directly for I'm not on here all that much. Thanks Dceder5495@aol.com
Old 06-17-2015 | 02:19 AM
Just a comment to the OP - posting your email openly on the web is an invite to spam which can render your email address useless. You may wish to edit the post and remove it.
Old 06-17-2015 | 03:01 AM
Lucky's Avatar
I have never tried to swap out from a different model before. I know on some vehicles the vin number has to Match the car or a trouble code will pop up.
I have swapped out a 04 sunfire cluster recently and all worked well the cluster automatically pulled the milage from other modules and displayed the correct mileage for the car.
Old 06-17-2015 | 07:20 AM
Is the mileage stored in the cluster or the computer (BCM/ECM)?
Old 06-17-2015 | 07:36 AM
From what I've read, it's not stored in the cluster. I believe the cluster is just a read out screen without storage or memory capacity.
BCM would be my thought, put not exactly sure.
Old 06-17-2015 | 08:30 AM
Lucky's Avatar
I'm believe the memory is in the bcm. My son install a cluster in his cobalt and was thinking it would read the low mileage from the car he removed it from.
He was kinda bummed when he turned the key and his car was still high mileage.
Orchidmoon72
Maintenance and Upkeep
04-06-2015 03:27 PM
banditorama
Mods - Interior
20
12-24-2012 01:37 PM
MIKEY 406
Mods - Interior
15
04-09-2012 08:15 AM
