LED's in third brake light - No cruise control. :(
Just replaced almost all the bulbs on the inside and outside with LED's from superbright.....everything was going fine until the third brake light.
Have heard that replacing those bulbs with LEDs will make the cruise control inop - was hoping not to have that problem but no such luck.
Anyone have a solution to fix this?
The stock bulbs are actually brighter than the LEDs but I like the LED look much better.
I guess I can just use wire taps to put it in line with one of the brake lamp main wires?
Don't have a solution, but a reason that you can work with. The cruise control goes off when the brake lights light up, that is were the "off" signal to the computer comes from. In cars that I have worked with the signal was sent directly from the brake light switch at the pedal "ground/no ground". Not sure about HHR or LEDs, just that's the connection between the brake lights and cruise control for your consideration, I know many people are scratching their heads wondering "What's the connection?"
Thanks everyone!
purple people eater
09-17-2016 01:07 PM
dbldown
02-19-2014 08:08 AM
hhrumadbruh
10-26-2012 07:53 PM
