Lowering the SS
Old 07-05-2009, 01:22 PM
bartSS's Avatar
Lowering the SS
Do any of you guys/gals know if these springs will fit the SS? Thanks in advance
http://www.truckshop.com/product.php?productid=20584
bartSS is offline
Old 07-05-2009, 05:13 PM
1Panel2NV's Avatar
They will fit.
1Panel2NV is offline
Old 07-05-2009, 05:14 PM
hyperv6's Avatar
How will you keep from scraping the front end?
hyperv6 is offline
Old 07-05-2009, 05:16 PM
1Panel2NV's Avatar
It's less than a 2'' drop up front, it's not like you're going to be laying frame.
Old 07-05-2009, 06:00 PM
bartSS's Avatar
Nice thanks bro ill be ordering them soon then. Cant wait to see the outcome
bartSS is offline
Old 07-05-2009, 07:14 PM
xzombiex66's Avatar
I don't scrape and i have the SS front bumper.
xzombiex66 is offline
Old 07-05-2009, 11:05 PM
IgottaWoody's Avatar
when you consider the LS/LT has a damn under the bumper and they don't scrape , the SS shouldn't be any lower, its just more visable..the only area to watch is curb stones and most of us by now stay far away from them as habit now anyways.With a short wheelbasr theres no reason to be parking over them anyways.
IgottaWoody is offline
Old 07-05-2009, 11:19 PM
xzombiex66's Avatar
The SS bumper does stick out alot further than the LT bumper, you jus need to go a littler slower.
Old 07-06-2009, 07:40 AM
hyperv6's Avatar
With SS lower you lose the lincline angle as it it out farther.
I added the retractactable plate to mine and lost about an 1 1/2". I now have scraped it several times including my driveway. Once it was on uneven ground in a parking lot where a ramp went down.
Curbs, holes, speed bumps, uneven ground, driveway and parking lot enterances will all be possible damage areas and you will not know till you hit.
The LS and LT are fine but the SS overhang being so farther out makes it worse.
My Fiero has a standard non GT nose with the DGP air dam that hangs down on a large over hanging nose. I have scooped up gravel with that one already. It is not a daily driver but I can not lower the car without inflicting damage to it.
Also don't know if you drive in the snow or if your SS is a daily driver but in the winter anything over a couple inches will push snow. I have to watch and make sure it is not hard snow or ice.
Just something to think about. I just see so many cars in the midwest with busted front ends here.
hyperv6 is offline
Old 07-06-2009, 08:02 AM
garagebuilt's Avatar
do it. id rather be low than have the front bumper
garagebuilt is offline
Quick Reply: Lowering the SS
