Magnaflow catback and down pipe prototype..
Curve looks good, but a lot less than what I would have expected given the "obvious" turbidity points in the stock system-- at the base of the downpipe, at every turn of the rest of the system, the $10 stock muffler, etc.
I think this is another clear indicator that the stock turbo is just all played out. We need more CFM throughput at the turbo before we're going to see any major performance changes to this motor.
BTW, thanks for being the mule on this one.
Only time will tell until some more companies jump on board.Based on what I saw on the dyno and how the car continued to make power as it got hoy I think the IC is doing a good job. Car just needs to hold boost
I am no turbo expert but I think there is a bit more room in the stock huffer. I think 300whp is very realistic as well as alot more down below 4500 rpms. I think the limitations are in the pcm an dcurrent tuning options.
I agree that the ECM is in the way, but if you look at CFM rate on the turbo itself, it's definitely running out of steam. Also, with the 30%+ increased flow you'd expect from the Magnaflow tubes over stock, that should translate into better output than your curve shows... ASSuming the turbo isn't all in already... which is my assertion. I would have expected something more along the line of what I've penciled in here--
If you look where the cursor is you will see a 20+ whp increase. Pretty dang good.:)
I still think it's the computer keeping things realitively close to stock. These new PCM's are not as adaptive as we have become with past GM products.
Time will tell... I thought it was intresting that my PCM showed up as a Solstice GXP when we hooked it to HP tuners.
#28
i agree, i think it is probably the infamous "nanny code" dialing it back. of course, there really isn't a way to find the true capability of the exhaust on a totally stock engine, as the only way to get rid of the nanny code (correct me if i'm wrong here, cuz i'd sure like to know lol) is with the Hahn tuner. install the tuner to get rid of the nanny code, and the tune is no longer stock. you could see full potential of it on a Hahn-tuned engine though, see what it really puts out then.
#29
If everyone wants to contribute $$ for a hahn tuner I would be willing to sacrafice.... I will dyno stock, Tuned and than tuned with exhaust/DP.
I would be willing to add $400.00 towards the fund so I need $600 to make it work...lol
#30
ha!!! i got one better cole...how about for what you're asking or cheaper,get me that exhaust and i'll dyno it with my ppc. got the call today from hahn and they told me i should have it by thurs.
i just hope the dealer fixes my car and it's done right . then i have to wait a few days or to be safe a week to make sure the code doesn't come back.
