Need info about 12v Outlet
SS Panels apparently have a 12v unit located in the rear, that allows hookup of devices running up to 40amps. Does anyone have one, and if yes, could you post a couple of pics. My dealer can't even find a parts number for one, and he alledges that without a parts number, he has neither the time nor the inclination to search HHR parts for it.
I would like photos, parts numbers, or diagrams on this outlet. Any and all help would be appreciated. I have the AA5 body on a 2009 LS.
panel 12v
it looks exactly like the 1 on the dash , a little black cap....you don't need to remove anything to get to it....but you would to install it.....mine is about 6in from the rear hatch opening and about 1ft up from the floor panel , on the pass side......i don't understand why any dealer wouldn't know this.....oh , mine is 08.
i assume it is
but i don't really know since i got it used....but think i rember seeing it on the sticker....yep , i just checked....it is listed as standard equipment on my 08 panel lt.....it reads - rear 40 amp auxilliary power connector.....and looked at it again , it is about 5ins above the place where you can sit the storage shelf that normally is the rear floor....my panel was lt but made to be 2lt at the factory, it sounds wierd but thats what the sticker reads....but the power aux thing is listed under the standard equipment list.....i don't know if this helps , but panels are sometimes (or mabe alltime) listed as commercial vehicles by gm.
