No Power Windows
No Power Windows
From the first day I test drove the car the windows did not work. The dealer said they would fix it before I bought it. While I was doing the paperwork they took it back and said they found a loose plug. Windows worked for about a day. Weird thing is they work every once in a while. So took it back and left it for a day, said they found a bad ground and fixed it, again worked on way home did not work next day except intermittently. Have not had a chance to get it back in for service yet (been two weeks). Anyone else have a similar problem? Another strange thing is since the second time they worked on it the fog lights will just come on out of nowhere every once in a while, I hit the button and they will go right back off.
Have your dealer check the fuse panel under the hood. Some connectors were not installed properly from the factory that can cause multiple problems throughout the car. The fuse panel has to be removed and the connectors removed from panel to verify.
My driver window sometime will not open right after I start up my car after sitting for a while. I almost always let both windows down and open the sunroof th instant I get in. Only the drivers window wont go. I've never had a delay in any other window. It always works after a second....sometimes 5 seconds. Weird
Called the dealer today, going to take it in Monday. What ever it was it went completely out. My drivers window is down with no way to get it back up. Pisses me off, I hope it does not rain.
