performance tunes?
I want catback exhaust, maybe DP depending on the gains, CAI, BOV set up, brembo brakes, anything but the plastic IC pipes, ECU chip, and maybe some modest lowering springs.
My name is Daniel and I am addicted to mods.
Have you looked at the stock DP? It looks like it's got a huge restriction in it right at the mount point. Not sure what the factory is trying to clear, but if someone can work out something without that narrowing at that point, there will surely be worthwhile gains.
The first step is admitting you have a problem
I would like a reasonably priced turbo back, 3 inches sounds good, that increases power but doesn't make it annoyingly loud. I think that will be the biggest issue with systems that are developed.
