Placing a order 09 Hrr SS
Old 12-10-2008 | 11:19 PM
tony326's Avatar
I am placing a order for a new HHR SS Dec. 15 with every options listed including AA5 package, i plan on upgrading turbo ,exhaust, intake, reprograming and dyno testing for horsepower after 3000 mile and hopefully gaining mileage when not heavy footed, i heard of a factory turbo upgrade for HHR, after several calls to the factory the dealer could not find anything.
after upgrades must i run 93 octane,will computer auto adjust timing, boost and air ratio after programing it for horsepower when using 87/89 octane is the range to far.
Automatic (wife wants auto) I heard automatic will not hold up to added torque and horsepower is there a kit to install to help, my 36,000 miles warranty made be voided if trans fails.
5sp stick is there a difference in final gear ratio.
optional boost/vacuum and info center for the center dash and rear camera setup has anyone seen these options are these dealer install and not factory item?
Old 12-10-2008 | 11:28 PM
More info on the upgrade here.......
https://www.chevyhhr.net/forums/2-0l-performance-tech-46/gm-performance-parts-turbo-upgrade-kit-19891/
The SS off the lot calls for 93 octane already.
Check this thread for the RPD.........
https://www.chevyhhr.net/forums/hhr-ss-45/reconfigurable-performance-display-18652/
Old 12-11-2008 | 09:10 AM
soccerjunky's Avatar
why buy an 09 when an 08 can be had for 18k new
Old 12-11-2008 | 10:10 AM
sargechris's Avatar
to the Site!! You'll love the SS!!
Old 12-11-2008 | 12:51 PM
tony326's Avatar
08 with AA5 option
i could not find a 08 with AA5 option fully loaded
Old 12-11-2008 | 01:46 PM
AaronSS's Avatar
My only suggestion is to make sure you drive a manual and an auto so that you can compare the two. Good luck.
Old 12-11-2008 | 09:31 PM
damronjr's Avatar
Come again, they don't even sell 93 here in CA, so how could they sell a car that they don't even have fuel for? It was my understanding that it just calls for Premium.
Old 12-11-2008 | 09:41 PM
jetttstream's Avatar
I believe it is 'premium recommended' but you are only 'required' to put in premium after the stage kit.
-Mike
Old 12-11-2008 | 10:11 PM
camaro98z28's Avatar
I ran 87, 89 and 91 Oct in mine and I only noticed a tad difference. I think people act like 93 OCT will give them godly HP.
Old 12-11-2008 | 10:15 PM
halfpanel08's Avatar
my last turbo car ran like balls if i ran lower than 93..
kinda suckd cause i had to get the good stuff everytime
Quick Reply: Placing a order 09 Hrr SS
