Power window switch and cruise intermittant...
Old 10-30-2008, 11:29 AM
CarlsSS's Avatar
Question Power window switch and cruise intermittant...
Anyone else had issues of intermittant problems with their cruise set/resume buttons or power window switch? Mine acts up once in a while and I know if I take it to the dealer they will probably find nothing. It only does it once in a while.
With the cruise, the on/off button seems to be active, as the light comes on. But the set switch will not work. The next time I start the car it always works...
The power window is the drivers/front, and it usually only does it the first time I use it after starting. If I switch it back and forth a few times it usually will eventually work. If I shut off the car and restart it also seems to work right away...
CarlsSS is offline
Old 10-30-2008, 11:44 AM
rommer's Avatar
I've experienced the cruise control issue 4 or 5 times. Each time it has corrected after depressing and releasing the clutch a few times. I think the clutch sensor/switch/whatever is sticking. That or the computer is not seeing the input.
rommer is offline
Old 10-30-2008, 11:46 AM
Clevelandhhrss's Avatar
I have had this exact (window) thing on mine. An I mean precisely the same issue as you.
LOL, since i was doing my ridiculus mileage thread, I'd always start everything before I turned the key,, so as soon as the car was cranked i could pull away. Most of the time I pulled away with 3 windows down... I have greater problems now.
I was planning to start a thread when i found something out. But lets just say I have seen all possible dic messages flash at me in sequence, I have intermittant use of ALL POWER OPTIONS. And now, no power at all. Now I noticed that only the drivers door has a key hole :) I'm getting it towed from my parking garage as soon as I get home.
Clevelandhhrss is offline
Old 10-30-2008, 02:15 PM
jerSSey HHR's Avatar
My only problem with the cruise seems to be its vagueness when using the buttons to go up or down in speed.
jerSSey HHR is offline
Old 10-30-2008, 02:29 PM
Ratracer's Avatar
I agree with that. Why didn't they recess the buttons instead of putting in a delay if they wanted to prevent accidental hits that change speeds.
Ratracer is offline
Old 10-30-2008, 09:18 PM
CarlsSS's Avatar
Interesting.. I never thought about that switch. I will try pumping the clutch a few times next time it happens and see if it comes back. Thanks!
CarlsSS is offline
Old 10-30-2008, 09:23 PM
CarlsSS's Avatar
Wow, sorry to hear that! That sucks big-time! Good luck with getting it turned around quickly...
I wonder if the window thing is tied to the express-down feature. That is the differnece between that window and the others... I think I will ask the dealer to replace ithat switch when I take it in next time. Hopefuly not for something major like yours!
CarlsSS is offline
Old 10-30-2008, 09:27 PM
CarlsSS's Avatar
No kidding, the buttons and their locations suck! I much prefer them back on the turn signal stalk where they've been on GM's for years. I am constantly pressing back there as I am used to my other car & truck!
CarlsSS is offline
Old 10-30-2008, 11:17 PM
oneton's Avatar
What is the delay your talking about?
oneton is offline
Old 11-01-2008, 08:54 PM
CarlsSS's Avatar
I guess I have personally never noticed a delay... I think the biggest issue with the buttons and their location is all 4 button on ea. side of the wheel feel & operate the same. It's like you have to think about it or look at them to press one. I don't like having to constantly look down at the wheel...
CarlsSS is offline
Quick Reply: Power window switch and cruise intermittant...
