Ramps for the SS
Old 05-07-2008 | 08:15 PM
turbotim's Avatar
Ramps for the SS
I purchased some ramps to use when changing oil. They were the Blitz brand Rino Ramps sold at Autozone. The lower valance rubs and will not clear these ramps so I returned them. Wal-Mart ramps looked to be about the same.
What ramps are you guys using to change oil and where did you pick them up?
Old 05-07-2008 | 08:24 PM
CarlsSS's Avatar
Yup, that can be a problem... I have a fairly shallow set of ramps I made in high school shop class way back, and they are still too steep. I stack up a couple of planks in front of each one and a small board on the ramp itself and it works fine. Would be bettter if it was attached of course...
Old 05-07-2008 | 08:53 PM
white heat's Avatar
My srt is lowered so I screwed two 5/8" boards together for each side and no problems.
Old 05-07-2008 | 09:38 PM
Tony_SS's Avatar
Former Sponsor
Please - do not use ramps! Get yourself a nice a decent jack and jackstands. Also, put wheel chocks behind the rear wheels. Ramps are a recipe for disaster.
But in all reality, my local shop charges me $21 for a full synthetic oil change. Ask yourself it changing your own oil is worth the cost of having it done.
Old 05-07-2008 | 09:53 PM
I agree, it's not worth it to me. I pay to have minbe change and for the ability to go online and print out a record of each one by vin#.
Old 05-07-2008 | 11:13 PM
xzombiex66's Avatar
yes get a low profile jack and you will be set.
Old 05-08-2008 | 12:45 AM
white heat's Avatar
Nothing wrong with ramps if you use them correctly. Actually ramps are safer and easier to use if you don't need the tires off for any reason. I have a floorjack and jackstands if I have a need for the car up and wheels off.
Old 05-08-2008 | 06:13 AM
solman98's Avatar
Always worth it IMO.
Ramps are as safe as any jack and stands. Both can fail. But it's easier to tip over a stand.
Old 05-08-2008 | 07:42 AM
jayhawker's Avatar
Where the heck do you get a full synthetic oil change for $21? Does that include the oil also? If so, they can't possibly be making any money at that shop.
Old 05-08-2008 | 07:51 AM
Tony_SS's Avatar
Former Sponsor
It's a local owned Auto parts and repair shop down the street. The oil is Kendall Synthetic and the filter was included. But when you buy oil by the 55 gallon barrel, a quart comes out to be pretty cheap. Anyway, that's what they charge so there's no sense in me going through the trouble.
Quick Reply: Ramps for the SS
