Reconfigurable Performance Display
#53
#54
there is one reason why this is better than all of the aftermarket gauges. it has a warranty. the RPD is over 25 gauges in one. it is a:
boost
A/F ratio
cam phase angle
spark advance
spark knock
engine power
engine torque
speedometer
laterial G-force
left G-force
right G-force
maximum G-force
shift light
gear indicator
individual wheel tire pressures
Barometer
outside air temp
battery voltage
coolant temp
air inlet temp
fuel pressure
plus the following indicators:
stabilitrak, traction control, ESC, competition driving mode, and launch mode
boost
A/F ratio
cam phase angle
spark advance
spark knock
engine power
engine torque
speedometer
laterial G-force
left G-force
right G-force
maximum G-force
shift light
gear indicator
Barometer
outside air temp
battery voltage
coolant temp
air inlet temp
fuel pressure
1. INTAKE AIR- Intake Air Temperature - **
2. COOLANT TEMP- Engine Coolant Temperature **
3. TRANS TEMP 1- Transmission Temperature for automatic gas vehicles
4. RPM- engine Revolutions Per Minute **
5. MAF SENSOR LB/M- Mass Air Flow (lbs/min) **
6. MAF FREQUENCY- raw Mass Air Flow sensor output (frequency)
7. MAF FREQUENCY 2- raw MAF sensor output for the Cobalt SS and Redline
8. MAP SENSOR- Manifold Air Pressure (kPa) **
9. BOOST – Intake vacuum/boost displayed in inHg/PSI. Corrected by altitude entry or barometer**
9. THROTTLE POS. PCT- Throttle Position percentage (0-100%)
10. THROTTLE VOLTS- Throttle Position sensor output (0-5 volts)
11. MILES PER HOUR- Miles Per Hour **
12. KNOCK RETARD- Knock Retard (degrees) for most GM vehicles
13. KNOCK RETARD 2- used for KR value of ’94-’97 LT1’s and some 96/97 V8’s.
14. KNOCK RETARD 3- used for knock retard value of the Cobalt SS SC and Redline HHR SS
15. IGNITION ADVANCE- ignition timing advance
16. PULSE WIDTH- injector #1 pulse width (4&6 cylinder engines)
17. SHORT TRIM B1-short term fuel trim bank#1
18. SHORT TRIM B2-short term fuel trim bank#2
19. LONG TRIM B1-long term fuel trim bank#1
20. LONG TRIM B2-long term fuel trim bank#2
21. OXYGEN SENSOR B1-O2 bank 1 sensor in millivolts
22. OXYGEN SENSOR B2-O2 bank 2 sensor in millivolts
23. RUN TIME MINS- engine run time is tenths of seconds since last engine start **
24. BATTERY VOLTAGE- Alternator/battery output voltage **
25. IAC POSITION- Idle Air Control counts (position of Idle Air Control valve)
26. PULSE WIDTH B1-injector Pulse Width for bank 1 (8 cylinder engines)
28. ENGINE LOAD- calculated Engine Load (0-100%) **
29. ENGINE OIL PRESSURE (some 8 cylinder engines) **
30. INTAKE AIR 2 – Intake Air Temp. downstream of intercooler (some supercharged applications such as the Cobalt or HHR SS
SS, Ion Redline).
31. Miles Per Gallon 1- instantaneous fuel economy for gas vehicles
32. Miles Per Gallon 2- instantaneous fuel economy for diesel vehicles
33. HP 1- Calculated net horsepower for gasoline vehicles
34. Analog 1 – analog input #1.
35. Analog 2 – analog input #2
36. TOTAL MISFIRES- Total misfires of all cylinders. Resets every minute.
37. BAROMETRIC PRESSURE- limited support on standard GM vehicles,
38. Altitude
39. Shift light
40. performance recorder
41. Will read 0-60-1/8 and 1/4 mile times and speed
42. Will read trouble codes
43. Will clear trouble codes
44. Gear selector
And more features like Fan control and other adjustable settings on the engine.
I already have in my standard SS Info center and dash
boost
speedometer
gear indicator
outside air temp
coolant temp
stabilitrak,
traction control,
ESC,
launch mode
The only thing I really lack is the G meter and colorful display with my aftermarket Aeroforce scan meter. It really offers as much or more and I keep my storage.
It is easy to install in 5 min and has a warranty. It really the same thing as GM's just taken to the next level.
The Chevy one is nice but I like the one I bought better. Just my call.
Note my list of the Aeroforce meter is editied to remove most of the features that it offeres for the non Ecotech engine. I may have missed something or not added a feature somewhere.
#57
boost
A/F ratio
cam phase angle
spark advance
spark knock
engine power
engine torque
speedometer
laterial G-force
left G-force
right G-force
maximum G-force
shift light
gear indicator
Barometer
outside air temp
battery voltage
coolant temp
air inlet temp
fuel pressure
boost
A/F ratio
cam phase angle
spark advance
spark knock
engine power
engine torque
speedometer
laterial G-force
left G-force
right G-force
maximum G-force
shift light
gear indicator
Barometer
outside air temp
battery voltage
coolant temp
air inlet temp
fuel pressure
#58
Yup, here we go again. I bought a new '65 Chevelle SS and if you ordered the tachometer it went in the place where the clock was and the clock was mounted in a pod on top of the dashboard whether you wanted it or not. My father worked at the factory and even he couldn't stop the clock installation.
Some things never change.
#59
This is a horrible spot for the display. As much as I want this. I don't want it there.
Is there a way to get this install in a vehicle that didn't have one (in a different spot of course) or will it not be compatible with the wiring?
