Ss build
Old 10-21-2010, 11:04 PM
ssdivin's Avatar
Ss build
Well lost compression on #3 on my 2008 ss so pics will come
Spec stage 2 clutch
Spec flywheel
Ebc drilled rotors
Ebc green stuff pads
Arp headstuds
Wiseco pistons
Work will start monday
Head machined
ssdivin is offline
Old 10-22-2010, 05:42 AM
hyperv6's Avatar
Go Red on the pads and it will have less dust and work as well or better.
hyperv6 is offline
Old 10-22-2010, 07:06 AM
bartSS's Avatar
I dunno about the head man. ZZP went back to the stock head on a stock turbo and still ran an 11.xx
But if youre going big turbo then for sure. In the mean time you will lose a little bit of power with a ported head on the stock turbo
bartSS is offline
Old 10-22-2010, 07:15 AM
windsmith's Avatar
What's the reason for this? I would think better flow + same flash = same power but better efficiency.
windsmith is offline
Old 10-22-2010, 08:17 AM
JeramieJJ's Avatar
He will explain in more detail, my first guess is your still pushing same amount of air. you would actually be better off keeping head same and upping turbo for what your assuming. I am not positive, but I think the stock turbo is about out of steam with the current head....so bigger head is bad. Upping both is of course a great idea.
This is often done in error when building SBC V8 engines...many times too big of heads are put on.
JeramieJJ is offline
Old 10-22-2010, 09:02 AM
ssdivin's Avatar
I will be puting a big turbo after the motor.
ssdivin is offline
Old 10-22-2010, 11:03 AM
JeramieJJ's Avatar
Ah, then your planning is perfect.
Old 10-22-2010, 12:14 PM
bartSS's Avatar
Yes the stock head is more then enough for the stock turbo but since youre going big turbo then youre right on track man. Best of luck with the build . I was gonna build mine but im actually selling all the aftermarket stuff now and will be selling the car.
bartSS is offline
Old 11-06-2010, 09:28 PM
ssdivin's Avatar
ssdivin is offline
Old 11-06-2010, 10:04 PM
ssdivin's Avatar
Oh new turbo and intercooler ect ect
ssdivin is offline
Quick Reply: Ss build
