SS gas and reliability
Old 04-22-2011 | 09:22 PM
urbexHHR's Avatar
Thank you
Old 04-22-2011 | 11:29 PM
Father Azmodius's Avatar
Originally Posted by Gas Man
I'm with ya Bart. I think there is 2 very different POVs on "putting their foot into it".
24 of the 25.5 miles I drive to work are highway. That may be where the difference comes in.
Old 04-23-2011 | 07:33 AM
hyperv6's Avatar
Originally Posted by urbexHHR
Thank you
No problem it is a legit question to a much debated issue.
Old 04-23-2011 | 11:19 AM
Fueluser's Avatar
I know all you SS owners are chuckling... but how do you know when the car has a stage 1 installation? or anything above a factory plain 2.0 engine. Is the give away the do hicky on the dash where the storage compartment would be? Laugh away.... I have a 2.4 that has a weapon R intake (and has never threw a code ever) that I beat quite regularly and with regular gas and never did care about the gas mileage so I am not cheap per say...(to the person who through that i might be - my primary passion is collection vintage gas station items... thank you). Thanks. John
Old 04-23-2011 | 12:26 PM
hyperv6's Avatar
You step on the gas and go
There are a couple ways to tell. The gas lid will say Premium Required vs the factory sticker Recomended. Under the hood the EPA sticker is updated to reflect the up grade. Also the Map sensors come off at a 90 degree angle vs straight up. The plugs will have new connectors and should be taped abut 7 inches up the wire.
Oh and the Boost gauge will top 20+ PSI with no issues.
The do hicky on the dash that is the performance dash. It was just an option in 09 and became standard on all SS later. It has nothing to do with the Turbo upgrade.
Old 04-23-2011 | 04:54 PM
  #26
Fueluser's Avatar
Thank you hyperv6. John
Old 04-23-2011 | 06:27 PM
  #27
So I have a "do hickey"? Learn something new every day. Now does anyone know where the "thingamajig" is?
Old 04-23-2011 | 07:32 PM
  #28
08bowtie's Avatar
re
thingamajig is connected to the hydraulic-a- riffraff which is right next to the syphongitis...
Old 04-23-2011 | 08:49 PM
  #29
Gas Man's Avatar
That could definitely be the trick. As long as you keep it under 80.
That is part of the performance package NOT the stage 1.
Old 04-23-2011 | 10:47 PM
  #30
I've found that mileage is optimized at 55 (30+mpg), 70-75 is about 27ish, but 90 is bad for mileage, unless drafting off a motorcoach (40mpg)
