Does any one know if a SS rear Sway Bar will work on my 2LT truck??Will it bolt up to the 2 LT ??Or what will I need?? I can get one from a salvage SS truck.
Since the SS or any HHR did not come with a removable rear swaybar, (excluding the oe torsion bar). This must be aftermarket, & should fit any HHR...
Fwiw: Once removed, lay it on a flat surface to see if it is twisted or warped..
