Stage 1 in Las Vegas
Old 08-22-2009 | 02:50 AM
jlamb's Avatar
I have read many many threads on this site about the stage 1 upgrade and I want to upgrade my car now. I am located in Las Vegas and wondering if anyone around Vegas has had this kit installed yet? I called the dealer in Henderson and the service adviser told me it would take at least 4 hours to install and the labor rate is $99 an hour. This seems a little crazy to me. I then asked if I could do the wiring myself and just have them re map the computer and he said they would not touch it unless they did the whole job. Needless to say I need a place to get this done and I am wondering who in the Las Vegas area will install this and how much will it cost?
Thanks for any info..
Old 08-22-2009 | 03:09 AM
stephenm's Avatar
try a different dealer. i was quoted $100 at one place and $180 at another for the complete install, based on 1 to 2 hours @ $89 an hour.
I had one dealer refuse to touch the upgrade.
the kit calls for 1.2 hours from everything i have read, but since it is not in the book they like to charge actual time.
but maybe if they can look up changing the tmap sensors and reflashing the ECU, it may come out to the 1.2 hours
P.S I just bought a new stage kit off ebay for $385 and $9 shipping. So look around for the kit.
Old 08-23-2009 | 06:57 PM
MOTRV8D's Avatar
4 hours to reset a computer does sound a little crazy to me too.
What a greedy gut that dealer is. That's how some of them get the name stealership.
Old 08-23-2009 | 08:23 PM
Neogenic's Avatar
Four hours is silly. Downright silly. You should report them to GM and the newspaper for fraud. That's sickening.
Old 08-23-2009 | 10:28 PM
HHR SS 1st's Avatar
there has to be more than on gm dealer in vegas
Old 08-24-2009 | 09:51 AM
More_Torque_More_HP's Avatar
Here are the GMPP Dealers in the Las Vegas Area. Try one of them. Ther recommended install time for the HHR including the calibration down load is 2.0 hrs. The 1.2 hrs is for the Solstice/Sky.
Distance:
4.4 Miles FAIRWAY CHEVROLET
3100 E SAHARA AVE
LAS VEGAS , NV 89104 -4301
Phone: (702 ) 641-1400 Fax: (702 ) 641-1499
Distance:
12.0 Miles HENDERSON CHEVROLET CO.
240 N GIBSON RD
HENDERSON , NV 89014 -6700
Phone: (702 ) 558-2438 Fax: (702 ) 558-2499
Old 08-26-2009 | 09:51 AM
stephenm's Avatar
can the calibration be downloaded by someone, while the tech is swapping out the sensors?
i'll pass it on, before they do the install.
also should they upgrade to t-clamps? as there are several instances of clamps blowing off due to increased boost
Old 08-27-2009 | 07:34 AM
If they have more than one tech working on the car the cal could be being downloaded by someone else while the parts are being installed
I would make sure the clamps are tight. If you want to upgrade it would be a good time to do it. It is not necessary to upgrade the clamps. Just make sure they are tight.
Old 08-28-2009 | 01:00 PM
stephenm's Avatar
their vette tech did the install, and i dont think he even removed anything, took 2 hours everything is fine, he was saying they should have designed the lower sensor like the old one because it is very close to the a/c unit.
then again vette techs are used to working in cramped spots
I mentioned how I heard some people are having connector problems, and he said that their install tech is probably using the wrong crimp tool.
so we didn't upgrade the clamps anyways, he said no problems there
raydnvegas
09-21-2009 12:27 PM
SindyDix
South Pacific
01-06-2009 02:12 AM
Buckweed
South Pacific
09-15-2008 08:30 PM
Songman
South Pacific
08-06-2006 05:11 PM
