Thinking out loud! Comments
What if you get a second computer for your ss and put a tune on it.
Then if there is a problem put the original back in for warranty work.
Since it does not appear that GM is going to finish the GM Warranty Tune
yes no
yes no
from what i have read odometer is not related to the ecu.
all of the forums and post i have read said that GM was working on one but funding was cut and there is no idea when if ever a gm tune will be available.
no idea if that is the case or no just exploring other options
i want to do something but i want to keep the warranty also.
PCM is a quick physical swap. Based on other vehicles, I would imagine a "relearn" is then required... don't know the procedure, but could be similar to other GM vehicles, which is a sequence of key on - key off moves that takes 15-20 minutes to do. However, since this PCM is Bosch... which is new for GM, who knows what, if any process is required. Having said that... it absolutely MUST be swappable or the car would have to be thrown away if the PCM died.
