Tire sizes
Old 03-14-2011 | 07:52 PM
SOMBERSHARK0714's Avatar
Tire sizes
Ok, the stock oem tire size on HHR SS's is 225/45/18.
What i want to know is , will a 235/50/18 tire size work ?
Thanks in advance !!
Old 03-14-2011 | 07:56 PM
Try not to exceed 26 inches over all dimeter or it will rub the front strut lower plate. The 235/50 is 27.25 according to THIS CALCULATOR <--- you can click this
Old 03-14-2011 | 07:57 PM
Zagohhr's Avatar
I have 235/45 R17... I haven´t had issues with that. I would Install 235/50 R18... there´s is a big gap on the fender weel...
Old 03-14-2011 | 08:03 PM
235/45/17 is only 25.33 inches..... regardless of how much gap there is to the fender well, the clearance problem is that lower strut plate.
Old 03-14-2011 | 08:05 PM
BigRedGoat's Avatar
Not sure honestly, but the general rule is that the wider you make the tire, the shorter you need to keep the sidewall to retain the factory overall diameter. What you would be doing is increasing the tire width and height, and probably upsetting the T/C and ABS.
For a quick reference of how tire sizing works:
Tread width/% of tread width that makes up sidewall height/rim size
225/45/18 = 101.25mm sidewall height = Roughly 659.7mm OD = 25.97in OD
235/50/18 = 117.50mm sidewall height = Roughly 692.2mm OD = 27.25in OD
Old 03-14-2011 | 08:07 PM
Mrs. DLVRNIT's Avatar
Maybe a 245 x 40 x 18! A 235 x 50 x 18 will not work .....
Old 03-16-2011 | 12:54 PM
Yonash's Avatar
just ordered a set of Nitto 555 in 245/40R18 from the local Big Brand. They'll be here Friday.
and yes, i realize this is my first post on these boards in like a year and a half...haha
Old 03-16-2011 | 01:20 PM
bartSS's Avatar
Then we have the same exact tires
Old 06-06-2011 | 08:26 PM
HHRNYC's Avatar
How do you like these tires? I just blew my right rear tire and I after 30K miles I am looking for some new wheels. I drive a 2008 auto in NYC.
Old 06-07-2011 | 07:34 PM
HHRSSouth's Avatar
I run 245/40-18's also
