Took a little trip.. My thoughts
Old 08-11-2008 | 07:02 PM
stephenm's Avatar
So drove up to Lake George, NY on Sunday.
I ended up having to stay on cruise control because I was cruising at 80, without even realizing it.
I filled up on 93 ( it was 3.66 a gallon)
drove 280 miles round trip
average speed DIC 68mph
average MPG 32.5 mpg
I am impressed
Old 08-11-2008 | 07:07 PM
hyperv6's Avatar
I am impressed
I have noted on the web and even yesterday another SS owner and most are getting 26-27 city and 31-32 highway.
Mine also showed these number coming from Dayton.
Old 08-11-2008 | 07:10 PM
405HP_Z06's Avatar
Not me, best I've done so far is 23.67. I've got a little over 3,000 on the clock so far.
Old 08-11-2008 | 07:22 PM
dedecv3's Avatar
Yeah i can't seem to get above 24 no matter how hard i try. I've only got 1100 miles. Average speed is 38 MPH. I rarely get on the gas.
Old 08-11-2008 | 07:27 PM
Clevelandhhrss's Avatar
I am impressed
That's great for a 68mph average.
55mph =37mpg
60mph=35mpg
65mph=32.5mpg
70mph=29.5mpg
75mph=25mpg
80..well i never drive that fast long enough to know.
This is what I believe youll see if you use cruise. I dont use cruise so my number will be 2-3mpg higher across the range.
Drag is everything. Speed=fuel consumption.
Old 08-11-2008 | 07:37 PM
??? Not that driving the SS like you stole it is a bad thing, but DO YOU? Reset everything and check you highway cruise MPG's vs the ones I posted above. If that is what you see, the culprit is your foot.
You guys are simply having more fun in your SS than me. I have a 37 mph average over the last 400 miles and can't seem to keep it above 35mpg.
"Getting-on-the-gas" should be defined by your vacuum gauge going above zero. On the highway i don't let it pass above negative ten (-10) if I can help it. I 1-3-5 shift. Or 2-4/5 shift on a downhill.
https://www.chevyhhr.net/forums/fuel-economy-hypermiling-47/absurd-mileage-17070/
Old 08-11-2008 | 09:29 PM
Scrivs's Avatar
Those are some good numbers.....I am averaging about 15mi/gallon......not bad for a 1/4 mile track.....lol
Old 08-11-2008 | 09:49 PM
jerSSey HHR's Avatar
I've gotten 26+ MPG on the first two tanks, doing a lot of local driving and then getting on it quite a few times recently.
Old 08-11-2008 | 10:10 PM
dedecv3's Avatar
https://www.chevyhhr.net/forums/showthread.php?t=17070
I'm almost always in vacuum. Even when im first taking off it barely goes into boost. Highway i keeep it between negative 10 & negative 20.
Old 08-11-2008 | 10:22 PM
soccerjunky's Avatar
i've never gotten over 24mpg either ,, but it does get better mpg than any of my other cars so i aint complaining
