Trailer towing maximum (lb / kg): not recommended
Old 12-24-2007, 11:59 PM
PhoS's Avatar
I really like the SS but this is kind of a deal breaker for me. I have a hidden hitch and I regularly haul my dirt bikes around to go ridin. They need to come up with a tow rating for the SS
Considering what they changed I think the tranny might be the weak spot?
PhoS is offline
Old 12-25-2007, 10:25 AM
88ls1blazer's Avatar
That goes without saying :) I think you COULD tow w/ the manual, but it would probably need 94 oct. minimum to keep it safe.
88ls1blazer is offline
Old 12-26-2007, 07:46 AM
gcsd3742's Avatar
Just my opinion the Tranny is a weak spot had one before or should i say had 4 before had to keep getting them rebuilt so to answer your question the tranny's are weak
gcsd3742 is offline
Old 12-26-2007, 11:29 AM
Snoopy's Avatar
Just my opinion...but if you had to rebuild 4 transmissions on the same vehicle, I'd say the owner was a little weak....you obviously were over the vehicles limitations (overlooking the possibility of improper builds)..
Snoopy is offline
Old 12-26-2007, 01:06 PM
gcsd3742's Avatar
Was beating up on it to hard got it right the 4th time got rid of the vehicle...
gcsd3742 is offline
Old 12-26-2007, 01:11 PM
PhoS's Avatar
Were you blowing out trannys on a Cobalt or an HHR? I would defiantly be going for the automatic as its my daily. My LT 2.4 hauls the trailer , 3 dirtbikes , + 3people , gear and coolers pretty nicely. Fuel eco. goes down the tubes though
PhoS is offline
Old 12-26-2007, 07:54 PM
jeffs396's Avatar
I'm sure the SS is more than capable of towing light loads you speak of like your bikes & gear, chevy probably rates it this way since it's considered a "high performance vehicle", possibly the OEM tires don't have much of a load rating. If you are not concerned with a warranty infraction & really want an SS, I'd buy it & put a hitch on it!
jeffs396 is offline
Old 12-26-2007, 11:43 PM
Snoopy's Avatar
I actually think it might have something to do with the "spooling" of the turbo on a 2.0 ltr. engine.
Snoopy is offline
Old 12-27-2007, 11:05 AM
c2vette's Avatar
HHR Not a Good DirtBike Hauler
Trust me as a longtime Dirt Biker, using several vehicles over the years, what you would be happiest with is a small quad cab p/u truck or a Trailblazer. Possibly one biker, his gear, and a very light single rail trailer with one bike is max that the HHR is sensibly capable of when properly equipped.
c2vette is offline
Old 12-28-2007, 11:36 AM
PhoS's Avatar
I would defiantly prefer a truck so I can go faster then 55 (legally )The trailer I use holds 3 bikes. I've dragged it all over the place. To Mojave and back thru the hills fully loaded thru sand dunes, over mountains etc. My HHR didn't really seem to care much, it handles the load quite nicely. I don't think I would put much more in it as that would be pushing the class 1 rating.
PhoS is offline
Quick Reply: Trailer towing maximum (lb / kg): not recommended
