What octane do y'all run
Old 08-01-2014 | 11:44 AM
gunblaize's Avatar
87, 89, or 91
91 is the highest I can find around here, unless you pay out the wazoo at a few specialty gas stations.
Old 08-01-2014 | 12:13 PM
badassbowtie's Avatar
91 or 93. Only because I'm tuned. I assume 87 or 89 would result in pre ignition knock. But I don't know for sure. I'm pretty sure some Untuned guys have run 87. Maybe they'll pipe in.
Old 08-01-2014 | 12:15 PM
sinabu's Avatar
93 only
Old 08-01-2014 | 12:37 PM
Old Lar's Avatar
In my 06 HHR 2.4L, I mostly run 87 and after 134,000 mile, the car gets 30+ mpg average. I have tried running 93 (a 2000 mile experiment) and saw no mpg improvement, but did see a lighter wallet. 93 octane is $0.40/gal more expensive. I have even run pure gas which is $0.80/gal more expensive and also saw no mpg improvement.
I will note that the car seemed more responsive using the higher octane fuel, but the car is a daily driver and not a stop light to stop light drag racer.
Old 08-01-2014 | 01:07 PM
Old Lar. Are you trying to butt in on a SS discussion ?
Anyhow. 93 octane only with my GMTU. Average is right at 28 mpg per tank.
Old 08-04-2014 | 09:47 AM
Blue_SS's Avatar
93 or 94. The couple times it has had 87 in there, I have noticed a drop in MPG as well as it feeling sluggish. It didn't knock, though (stock settings).
Old 08-04-2014 | 12:29 PM
2005HHRauto's Avatar
On an HHR SS , 91 octane, is the minimum...
Anything less, will cause reduced power, & reduced engine life…
Boost + low octane = death...
The more compression that your engine has, you need higher octane, for a slower burn.
Boost = higher compression
Now, for non-boosted engines, read your owners manual, & try to use the
cheapest, lowest octane fuel, that the engine likes, without ping/knock...
The lower the octane, quicker burn rate, = better mileage...
87 = quicker burn rate
93 = slower burn rate
People that think that, "my baby deserves the best", with premium fill-ups, with an engine that only needs 87 octane,
pay the most, for gas with a slower burn rate, & therefore, get the worst gas mileage, ...
Old 08-05-2014 | 09:37 PM
XtremeSS's Avatar
E47
Old 08-06-2014 | 09:54 AM
Originally Posted by XtremeSS
E47
E47 = appox: 99 octane...
Octane calulator when mixing in Ethanol:
http://www.google.com/url?sa=t&rct=j...lEKlH5xvv8lryw
Octane is really a gasoline rating, as Ethanol octane rating, is just one part of a bigger picture.
Ethanol has a very high latent heat evaporation rate,
this means as the ethanol is made into tiny droplets ,
the Ethanol basically sucks the heat out of the air.
This drops the intake mixture temp like a prom dress.
This process helps prevent detonation, therefore you can use
more timing, compression, etc to build more cylinder
pressure, hence more horsepower (actually more torque).
Old 08-06-2014 | 10:38 PM
gunblaize's Avatar
Hmmm
This e47 stuff is interesting.
However, I would hate to go the e47 route and have the car tuned for it, and be stuck somewhere where I can't get any.
I've started running 91 after reading these comments. That's the highest octane I can find around here. I figure it's a small price to pay, and my mileage seems to have increased a bit.
