Wiring Questions
Wiring Questions
This is pretty difficult without a wiring diagram, and I will get one as soon as I can, in the meantime, does anyone know which wire in the right footwell fusebox area goes to the interior lights (dome and map)? Not just the fuse obviously, but the actual controlled wire. I want to add a couple of footwell LED's (already converted dome light to Blue LED's, so the current (load) is way down.
Is it necessaray to wire footwell LEDs to the dome light WIRE as opposed to the dome FUSE to have them respond the same (on/off) as the dome lights do ? I thought wiring them to the same fuse would do it ???
I know what/where the BCM is... after that, I'm hearing Chinese....
