Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
#81
Camshaft Position Actuator Solenoid Prices
Hi everyone,
I finally got tired enough of the CEL and hard shift stuff after replacing the gas cap and the MAP sensor. I found the following website that actually has the parts (or so they say - I just ordered them today)...both the intake and exhaust solenoids. For quite a decent price, I might add. The retail price each is $50.05 (USD), but check out my order confirmation below. Free Fedex shipping, but they tack on a $7.99 handling fee. All in all, I thought it was a good deal, but I'll let you know once I actually have the parts in hand.
Website: http://www.gmpartscenter.net/
Ordered Items:
Item Detail Part# Qty Price Total
VALVE
Make: Chevrolet 12628348
1 $34.24 $34.24
F-VALVE
Make: Chevrolet 12628347
1 $34.51 $34.51
Order Date/Time 2011-09-26 15:17:19
Shipping Method FedEx Ground 48 States
Estimated Shipping Amount $0.00
State Tax [] $0.00
Freight Amount $0.00
Amount Adjusted $
Handling Fee $7.99
Estimated Order Total $76.74
By the way Whopper, EXCELLENT how-to...saved me tons of agravation...![Big Grin](https://www.chevyhhr.net/forums/images/smilies/icon_biggrin.gif)
Guido
Ordered Items:
VALVE
1 $34.24 $34.24
F-VALVE
1 $34.51 $34.51
State Tax [] $0.00
Amount Adjusted $
Handling Fee $7.99
Guido
![Guido49 is offline](https://www.chevyhhr.net/forums/redzone/statusicon/user_offline.gif)
#82
Update -
I received these today. They are indeed GM OEM parts as advertised. They are exact replacements. I measured the resistance of both as soon as I got them, and they both read right around 10.5 ohms. The original exhaust valve measured 21+ ohms. I'm gonna put 'em in today and hope for the best.
#83
Guido49 - good deal on the price. And thanks for measuring the resistance of the solenoids - that 10.5 ohms will be a handy thing for diagnosing problems. Did you get the readings for the codes generated by the CEL?
Once replaced, you can put the original intake solenoid on the shelf as a spare, and don't forget to disconnect the battery in the trunk, at least momentarily, to reset the CEL once they are replaced. (it isn't really necessary to disconnect the battery for the replacement of the solenoids, as you will be doing the replacement with the power off).
Best of luck.
Best of luck.
![whopper is offline](https://www.chevyhhr.net/forums/redzone/statusicon/user_offline.gif)
#84
Well, it's done...took 35 minutes from start to finish to replace both solenoids (Valves).
After the test ride, everything was working as it should, i.e., no hard shifts. The CEL was still on (but I forgot to disconnect the battery...big DUH!), so I shut the car off for approx. a minute, then restarted it...CEL went out immediately.
By the way, the part numbers you listed originally were apparently replaced...at least by the above-mentioned site. For your reference:
12628348 = 12646784
12628347 = 12646783
12628348 = 12646784
12628347 = 12646783
#85
Ahhhh good job Guido. 35 minutes!!! Maybe we should have a contest to see who can do it the fastest. LOL
Thanks for the new part numbers. Glad it all worked out for you man. :)
#86
12628348 = 12646784
12628347 = 12646783
12628348 = 12646784
12628347 = 12646783
![ChevyMgr is offline](https://www.chevyhhr.net/forums/redzone/statusicon/user_offline.gif)
#89
![Question](https://www.chevyhhr.net/forums/images/icons/icon5.gif)
Long story short. My 2006 HHR 2.4 has a shifting problem just like a lot of people have had.
What I have done so far thanks to many suggestion on cheyhhr.net
Replaced both Camshaft Sensor's Autozone Part Number: SU8902
Had a transmission flush and filter
Checked the mass air flow sensor and connections
Still have the issue
My next question is what is the Autozone part numbers for the two items blow because I must be missing something and I don't want to buy the incorrect parts.
By the way Whopper GREAT POST![2 Thumbs Up](https://www.chevyhhr.net/forums/images/smilies/twothumbsup.gif)
Part numbers:
12628348 - Exhaust cam solenoid
12628347 - Intake cam solenoid
8. Use compressed air to remove any dirt/debris collected around the base of the solenoids.
Close-up shot of the immediate area:
![](https://www.chevyhhr.net/gallery/files/4/8/6/5/cs8.jpg)
http://lh5.ggpht.com/_JhwqJ2McqtI/S6...0/CIMG3493.JPG
Part numbers:
![bigbear2k is offline](https://www.chevyhhr.net/forums/redzone/statusicon/user_offline.gif)
#90
No idea on the Autozone part numbers. But if you get them from Autozone, post the part numbers here for others reference. And if you get them from Autozone, make a note of which is the intake/exhaust for ease of installation.
Myself, I'd stick with the GM parts rather than an aftermarket. GM now recommends some updated parts as noted below. I'd expect they would be updated in comparrison to the aftermarket ones, so I'd go with GM.
The GM numbers are as follows:
------------ Original-----Updated
Exhaust 12628348 = 12646784
Intake 12628347 = 12646783
Good luck
Good luck
