Dome light turn around...
I'm new here and just got an 08 HHR Panel with the 2.2 a couple weeks ago. Lovin' it so far, but confused by the dome light configuration.
So, I did some digging and in about an hour, I turned it around so that the "interior lights on" part faces forward and the push-on "reading" lights face aft. Wow! Much better (what were they thinking?), I actually have useable light in the drivers seat when needed now!
Has anyone else done this? Anyone interested in details? I didn't take any pix, but I could if it would help anybody. It was really pretty simple, but if you are prone to breaking things, you might not wanna try :)
I guess the Panel version has the same dome light as the others just cuz that meant no changes. Plus, now with it turned around, I've got groovy push on aft cargo lights whenever I need em.
I'll try to get my how-to on the turn around posted in the next couple days.
Just turned mine around what a great idea thanks.
1. Pop off lens to the light that comes on when you open door.
2. Use screwdriver and push back on the 2 clips carefully.
3. The housing should snap off leaving the light housing.
4. Pull down on the headliner until you can pull out the housing.
5. I had to reach above the headliner and pull the wires loose they were not
long enough, mine were glued to the liner.
6. Pull the liner back down and install light facing foward clip the housing on
install lens.
Just take your time and dont force anything. It makes a BIG differance at night you could read a map. Hope this helps.
install lens.
