Fuel line follies!
Old 09-01-2024 | 06:19 PM
  #101
What do you mean by negative battery fuse?
Old 09-01-2024 | 06:32 PM
  #102
Yeah, I’ll say it. Wrong forum section again.
Old 09-01-2024 | 06:45 PM
  #103
geeohnyoun's Avatar
Sorry it’s just the battery fuse in the back. My dad called it the negative battery fuse
Old 09-01-2024 | 06:46 PM
  #104
geeohnyoun's Avatar
I am new here and saw that OP replies with answers to questions about changing fuel line.
Old 09-02-2024 | 10:07 AM
  #105
keithmason22's Avatar
Its
p0446
Old 09-02-2024 | 01:59 PM
  #106
Originally Posted by keithmason22
Its
p0446
did you cut the line straight across, is it fully seated into the coupler?
This is the coupler that came with my kit.
Old 09-02-2024 | 02:05 PM
  #107
Can you blow air through the EVAP valve, it should be closed
The under hood valve
Old 09-02-2024 | 02:31 PM
  #108
Originally Posted by geeohnyoun
First I removed the negative battery fuse, then cut out the corroded part of the fuel line and replaced it with 5/16” rubber tubing.
I tried starting the car but it’s not working. Even with starter fluid.
The fuse was removed for like a day before we started working on it. Any help?
That is NOT a battery fuse. It is the fuse for the BCM computer.
Removing for a time should not affect the starting, not replaced fully or blown would.
If your aim is to safely work on the electronics you should remove the negative lead on the battery.
Old 09-17-2024 | 09:27 PM
  #109
did I cut the line straight and fully into the coupler? Yes. That is the feed line though. I am getting error code P0446 after changing the fuel lines.
Old 09-18-2024 | 07:37 AM
  #110
Have you tested the under hood EVAP purge valve?
SnoopHHR
10-14-2018 05:46 AM
budzone
05-16-2018 10:30 PM
Leroy Cook
Maintenance and Upkeep
7
04-02-2018 09:57 PM
Grizzly old man
28
11-13-2015 12:16 AM
SSROADSTER
"How To" Tutorial Library
04-16-2011 03:05 PM
Quick Reply: Fuel line follies!
