Fuel line follies!
Old 10-28-2019 | 05:49 PM
  #31
You don’t use the 3/8 tool, you squeeze the two sides of the plastic coupler, round side up , flat side down, with a pair of pliers, then gently wiggle the plastic coupler and pull the metal bundy out of the plastic fitting.
Your right the tool will not release the locking plastic spring .
Best picture, I could find, squeeze them sides not the round and flat , the green part will open up and unlock the bundy.
Old 10-28-2019 | 07:16 PM
  #32
Den Matlack's Avatar
thanks will try tomorrow have to be in work at 6am get up at 430am again thanks for getting back to me went to the Chevy dealer and they told me to use that 3/8 tool.
. What do they know
Old 10-28-2019 | 09:29 PM
  #33
Tools , same wild goose chase they sent me on.
Old 10-29-2019 | 09:48 AM
  #34
well I reached my limit tried everything even your idea still will not come a part taking a break for a while because I'am really frustrated
Old 10-29-2019 | 12:53 PM
  #35
just looked at it one more time decided to cut the line at the connection and use 3/8 fuel line and clamps thanks for all your help
Old 10-29-2019 | 04:01 PM
  #36
You’re welcome, sorry it didn’t work for you
Old 10-29-2019 | 08:58 PM
  #37
Good luck with the hose & clamps. I'm sure you know that is a hi-pressure line.
Old 10-30-2019 | 03:44 PM
  #38
If you cut the OEM steel line and the new steel line , you should use a compression union to mate the two steel lines together.
Old 10-30-2019 | 08:48 PM
  #39
Yep, agreed.
Old 10-30-2019 | 09:04 PM
  #40
let you know tomorrow whatI hope to do thanks for the advice I have a trick up my sleeve and these lines are the nylon like Old Blue used
Quick Reply: Fuel line follies!
