Fuel line follies!
Old 08-14-2020 | 02:09 PM
  #51
The metal fuel line at the fuel injector feed line? Use the 3/8 fuel line tool
Old 08-14-2020 | 02:34 PM
  #52
Originally Posted by Zachary Morgan
The quick connect nub on the metal line.......how do I make that work for the quick connect all I have right now is metal line and compression fittings. HELP!!!!
You're going to have to be clearer.
Are you saying that the new lines have quick connects, but what's on the vehicle does not?
Old 08-14-2020 | 03:48 PM
  #53
Zachary Morgan's Avatar
Sorry for not being clear, the line into the gas tank is a quick connect and the metal line is supposed to have a nub about an inch back to clip onto. How do I make that nub.
Old 08-14-2020 | 03:55 PM
  #54
Old 08-14-2020 | 04:04 PM
  #55
Use a compression fitting and an adaptor
3/8 or 10 mm compression fitting
And this adapter, you might need to cut it in half
Old 08-14-2020 | 04:09 PM
  #56
Then there’s the possibility or renting a flare tool like this
https://www.toolsource.com/flaring-t...t-p-91005.html
Old 08-14-2020 | 05:18 PM
  #57
Or, cut the old end off insert it into the compression attached to the new.
Old 08-14-2020 | 08:09 PM
  #58
Depending on the corrosion, a great suggest, but I thought the male end was cut off because the female plastic part was stuck to it.
Old 08-31-2020 | 09:54 PM
  #59
Radco's Avatar
Well I am not in the leaky fuel line club anymore lol Back on the road, But man a fuel leak near exhaust ;O
Old 09-03-2020 | 05:04 PM
  #60
Ronnie's Avatar
I hope I don't end up with THAT problem. Looks too much like plumbing. And I have been doing household plumbing for the last 3 weeks or better and I'm about over it! Plumbing manufacturers need their asses beat...just sayin. It is ridiculous it's not standard fittings between brands. Off my soap box.
Quick Reply: Fuel line follies!
