Outlaw filter with CGS, 2.4L
Here some pic about the installation of the CGS with Outlaw filter,
1- Grind the bolt hole of the windshield bottle, becarefull to nut crack the bottle.
2- Push the bottle a bit to the firewall(to right in this view), tight back your 3 bolts.
3- Put some tape on side of body to protect paint from filter when you will put it in place, very tight fit
4- Put back the intake pipe in place, a) You tight filter first, b) you tight your intake to throtle elbow, c) tight bolt intake tube to Valve cover.
And Voilą!!
Regular CGS filter & Outlaw filter
Here a video, Stop to full throtle (Sorry video not very good...)
Thanks to Mike from Socal HHR's for the amazing service,
And Voilą!!
Sound seam same as regular filter, performance seam a bit more but I use my HHR to drive to college during weekday to Montreal, I will let you know at the end of the week, but logikly the way the filter is made should be way better than the regular one, I order two, one for the HHR and one for my Z24
Thanks for your commentary, I will make other one shortly:
- Stuby antenna
- Sirius radio
- Stuby antenna
- Sirius radio
