Replacing the TPMS sensor battery
sensor of order died. I decided to change the battery. Couldn't find the battery number, so used №2032
Soldered to the contacts. Covered with epoxy
Decided to replace the battery. Carefully remove the battery.
The original battery is 2045. I have not found one in our country. Has used 2032.
Gently solder the battery to the terminals. Fill all with epoxy resin.
The sensor is ready for operation.
You would still need to deal with the bead breaking, and the CR2032 batteries only last a year or two .
I think replacing the sensors every 2nd time you replace tires isn’t bad.
I also think you should check tire pressure every week with a good tire pressure gauge as a better way to ensure you are aware of the air pressure.
