Stock Radio Removal Guide
Originally Posted by adamlowery
I found it easier to open the vents and put a hand in each and pull straight out. Felt like it opened easier. Just my 2 cents
I'm going to get a pro-fit mount to install next to the radio so I can add on a PSP mount. I'm going to do that soon. These pictures will help becasue the mount is made for the chevy equniox and it is compatable with the HHR and Cobalt as well.
the chevy cobalt dash kit will fit all you have to do is cut the top tabs off the kits and it will go in it has the little pocket to hold what ever i have put it in my HHR. you will need a new antenna adapter also for your radio
thanks phillip
thanks phillip
