video-sway bar bushing replacement
Old 01-28-2015 | 10:47 AM
speedwagen's Avatar
After reading several threads about replacing the sway bar bushings, I found this repair video.
I hope it goes as easy as it does in the video!
Old 01-28-2015 | 11:20 AM
Good find - I'll move this over to the How-To section.
Here are two other related videos for noisy front suspension and hub replacement along with your find:
Sway bar bushing replacement:
Sway bar link replacement:
Wheel Hub/bearing replacement:
Old 01-28-2015 | 01:07 PM
Great videos for those who are willing to get dirty and change their own parts!
Old 01-28-2015 | 01:50 PM
... and save a few $'s at the same time.
None of them are what I would call a difficult repair, as long as one has the appropriate tools available, including proper support for the vehicle to ensure they stay safe.
Old 01-28-2015 | 01:57 PM
Twistedtat's Avatar
Excellent video. If only I had this when I changed mine. lol
Old 01-28-2015 | 02:05 PM
But the statement that both lengths of swaybar end links will work has me concerned, Donbrew is going to have a word or two about that!
Old 01-28-2015 | 02:25 PM
True that - best to stick with the 10" ones as the 12" ones can have interference problems.
Old 01-28-2015 | 02:36 PM
"Will work" is accurate. Don't add flawlessly though.
Old 02-03-2015 | 04:56 PM
speedwagen's Avatar
This may be obvious, but if your doing the hub replacement, you can break the axle nut loose by sticking a screw driver in the vent slots on the edge of the rotor. As you turn the axle nut the screw driver will bear against the brake caliper to keep the hub from rotating as you turn the axle nut...in short----Don't pull off the caliper until you loosen the axle nut. (lesson learned while my brain was out of gear)
pstar
13
08-22-2019 04:21 PM
Snoopy
12
11-28-2014 12:05 AM
DreamHHR
11-23-2012 06:10 PM
1970judge
04-04-2012 12:07 AM
hurst2001
09-21-2010 10:44 PM
