For Sale 09 HHR SS one owner
09 HHR SS one owner
Located in 03053, Southern NH.
The good - One owner from new 09 HHR SS 5 speed 139k with perf option including gauge, LSD and Brembos. Only changes from stock is the GM stage 1 upgrade. Fairly recent front brakes (rotors, calipers, pads) and new rears (all parts). Interior is clean and minimal wear. A/C still works fine.
The bad - Sunroof only tilts, does not slide. Clutch pedal does not always return completely, seems to be outside temp dependent. Maybe a slave problem? There is a slight noise which could be from the turbo or an exhaust leak more noticeable on initial startup.
The ugly - Trans has a slight bit of play in it like there is too much backlash. Could be a problem with the crush sleeve. Also the front bumper cover was repainted due to a hit of an object on the highway and has many stone chips now. Rest of body is decent with a small dent on drivers rear.
I was going to do a refresh on the car but the Mrs sent me in another direction. Looking for $4950 OBO. Contact by PM.
Nice SS for the age not a bad deal, great basis for a full restoration or just fix and drive it ! GLWS
Don Juan
2.2L Performance Tech
10
03-13-2008 06:28 AM
