2010 hhr
2010 hhr
I have a 2010 HHR all around pretty good car. Have my share of problems also.
Joined this forum to get advice and knowledge about my ride.
Right after the factory warranty expired the power steering went out along with the esc. Mechanic replaced power steering motor and re-calibrated the steering wheel. After a few days the esc light on again. It is a sensor in the steering column $1000. Drives ok without it.
I do need some help with some other things.
Blower motor makes a chirping noise that drives me crazy fix/replace?
Also want to install fog lights. I have a extra plug (that is not connected) behind the radio bessel is this for a fog light switch?
In the fuse box under the hood there is a fuse and a relay already installed. How do I hook up the wires. I appreciate any help.
Thank You
Thank You
Welcome to the site. I have installed factory fog lamp in an 07 hhr the connector your talking about should be for the factory switch on mine I had to install the wire between the body controller to the relay under the hood and get the body controller enabled at the dealer to make them work there are other ways to get around that but I wanted the dash indicator on the dash to work like factory. Do a search for factory fog lamps and you will find all kinds of info some cars have more wiring than other so you will have to do some investigation. Most parts can be found on ebay.
elvistar
09-02-2010 09:13 AM
-md- HHR
Mid East
18
08-05-2010 07:29 AM
