The Black Swan
#185
I done with the primer, colour coats and clear coats, the rims look good, yes I remembered not to go nuts because they are my winter rims and snow tires. I measured the centre for the cap, ordered a set from Amazon, they’ll be here tomorrow. Then back in the shed till tire change day , Nov 1
I’m letting them cure overnight.
#189
Duplicolor, self etching prime, Duplicolor wheel paint Graphite gray, and Duplicolor gloss clear coat. I applied a light coat , waited 10 minutes then another light coat, waited 15 minutes then a little heavier coat for the last primer, then let that cure a bit over night. Repeated next day at same time in the afternoon for the colour coat, then next day for the clear coat. I used 1 can of primer, 2 cans of colour tge 1 can of clear coat.
coverage is very good and I refrained from my usual tendency to spray to much paint and waste it.
