HHR 2009 repair codes: PO325 & PO496
I just finished up with a month long investigation into the P0496, it was the EVAP purge valve up near the engine , three times the check engine light came on, I tested the valve by attempting to blow thru it , I couldn’t. The fourth time , I could blow thru the valve in both directions. After replacing the valve , no more pending code and no long hard starting after refueling.
allenworsham
05-16-2023 05:33 PM
RETRO-RED-EXPRESS
02-08-2011 10:13 PM
