I finally got one
I finally got one
Hey Everyone!
I've been lusting after an HHR since they were new on the market when I was in high school. Now, many years later, I am the proud owner of a 2006 HHR 2LT. It has a little over 200k miles but it runs and drives nicely and it was only $900. It's one of the most loaded HHRs I've seen which isn't an SS. It has power heated leather seats, power sunroof, premium audio with subwoofer, roof rails and running boards. It needs tires, but I've got a set of DWS06 Continentals from another car ready to go on. There's an oil leak down the front of the engine which appears to be the valve cover gasket and there's a small exhaust leak somewhere. I've always been a wagon guy, so this little guy fits my tastes very nicely.
Based on what I've read in this forum, I'm planning on upgrading the front brakes to the non-brembo SS rotors and I'll probably also get a rear sway bar in the spring.
Is there any general maintenance I should consider that would be outside of the usual, given the mileage? I'm talking about things like the water pump, VVT solenoids and O2 sensors
Yes, I’ve done over 75 of these , I’ve never removed the engine , you will need to support the engine and remove the upper engine mount to get the water pump bolt out. Loads of YouTube videos.
Matz
7
11-14-2021 12:48 PM
k9krazy
10-10-2015 12:48 AM
