new subscriber
Old 11-10-2011 | 10:57 AM
mcsean's Avatar
Question new subscriber
Hello all. I am new owner with an issue on my 2009 HHR LT. 2.0 litre motor with 8th vin digit of B. The problem is every time I drive, it stumbles at steady speeds of between 35 to 40 mph. Rpm's are always between 1100 to 1300. No check engine light (and yes it works) is on and no codes are stored. It is almost as if the throttle position sensor has a dead spot. Need some feedback please, the dealer of course finds nothing wrong.
Old 11-10-2011 | 11:48 AM
Welcome aboard, got to love the dealers they know what it is when it falls off. till then they need a code. Don't drive 38mph.
Old 11-10-2011 | 12:06 PM
LawDog88's Avatar
an LT with a 2.0? Really? Thought they had 2.4
Old 11-10-2011 | 12:14 PM
Rodney B's Avatar
Welcome
Old 11-10-2011 | 12:27 PM
to the forum mcsean!
B = 2.2L LE8 Flex-Fuel engine on a 2009 HHR.
Sounds like an issue with the TPS or the throttle body itself, odd that it hasn't set a code though.
Old 11-10-2011 | 12:46 PM
Welcome!
Old 11-10-2011 | 01:02 PM
DaGrinch's Avatar
Lots of good and knowledgeable people here. If you haven't found an answer to your problem by using the search function, Someone will probably come along with the answer. I believe I saw a thread on your problem a couple of weeks back.
Check this thread
The solution may not be in this thread, but as you can see, there's plenty of good suggestions. Detail in what is going on will help in pinpointing the problem.
Old 11-10-2011 | 09:50 PM
Grab a can of Throttle Body Cleaner & Clean it.. You'd be surprised the improvement possible..
Old 11-11-2011 | 12:33 AM
Lucky's Avatar
Welcome to the site
Old 11-11-2011 | 01:03 AM
HipHotRod's Avatar
That or
https://www.chevyhhr.net/forums/show...t=31305&page=4
Thread #31. My money's on this one.
