1st try in Photoshop Elements
This is the first attempt at pulling a car out of a pic.
Comments, opinions, advice are all very welcome!! ( I just noticed it needs some work around the stubby! )
This is a pic form the same day. (too lazy to upload the original that I chopped. )
I did the Mater chop of the HHR back in January. The thread has a link to a good tutorial on how to make your own. It gives pretty detailed information on using layers. Even if the CARS kind of chop isn't your thing, it is worth while as a learning exercise.
The thread is here: https://www.chevyhhr.net/forums/show...ighlight=mater
I just loaded that program. It came with scanner I purchased. I'm going to have to sit down and learn how to use it. I had an old version of Corel Draw and created some great t-shirts for my boys when they were younger. This looks like lots of fun!
this is how i work...
poly lasso (the one that does straight lines)
click around what you want to cut out.
you can hold "Shift" to add to the selection, and "alt" to subtract ("option" on a mac)
once you have your selection, hit command+J (ctl+J on pc) this will create a new layer from your selection.
