5 Myths about Stick Shifts
Old 08-21-2012, 09:54 PM
THE BATMAN's Avatar
I would like to make that comparison in person !
(Please)
THE BATMAN is offline
Old 08-22-2012, 10:56 AM
Panels4Life's Avatar
Originally Posted by nacademus
...and have less expensive repair costs when it comes time to service it.
Less expensive to replace it maybe but how often do you have to do that? Compare that to worn out clutches, throw-out bearings, sloppy bushings in the shift linkage, etc with a manual. I dont hear any complaints about AT but see all kinds of threads related to the shifter, clutch, etc.
Panels4Life is offline
Old 08-22-2012, 11:32 AM
solman98's Avatar
In general, at MT will outlive an auto. Replacing a clutch is nothing to replacing an auto as far as costs go. Even just a torque converter.
solman98 is offline
Old 08-22-2012, 04:41 PM
nacademus's Avatar
Clearly, you have never had to do either.
A clutch replacement is far less expensive. And, most clutch kits come with TOBs. If you know how to be easy on the TOB, then it will last a long long time. Bushings are cheap...Shift linkage?? You mean the cables? Keep them lubed and you are fine.
nacademus is offline
Old 08-22-2012, 06:11 PM
THE BATMAN's Avatar
I hit 97,600 miles today , Still pulls like new . Never thought the clutch would last this long . Boosted 26 ish with the new air box lid lifted 1 " today. Still tweekin it to get back to the 28 ish PSI .
Old 08-23-2012, 10:24 AM
nacademus's Avatar
Your boost will lower, the easier she breathes and exhales. Do you have exhaust and header mods?
Old 08-23-2012, 02:08 PM
THE BATMAN's Avatar
Nope.
Old 08-23-2012, 02:39 PM
Breadfan's Avatar
Lifting the lid seemed to give me about 6% trim increase and 9* temp increase. The air increase seems to outpace the temperature penalty unless it got stupid hot out. 28psi times 94% equals 26.32psi.
Breadfan is offline
Old 08-23-2012, 03:03 PM
foolmoon_design's Avatar
That don't seem right.
Chris what tune are you running, I would love another three or four pounds.
foolmoon_design is offline
Old 08-23-2012, 03:12 PM
Father Azmodius's Avatar
I'd say compare boost and MAF from before to after.
Father Azmodius is offline
Quick Reply: 5 Myths about Stick Shifts
