rim fitting
rim fitting
this isnt for an HHR but my girlfriend has a 2004 Hyundai Accent and its a 4 bolt setup...there is someone who is selling a set of pink rims from their 2012 Civic which is a 5bolt. Im wondering if these will fit considering the pink rims are a multi-fit rim with a 10bolt pattern. They are saying it will fit a 4 bolt..but i thought if it has a 10bolt then it will only fit a 5 bolt....but if it was an 8bolt then it would fit a 4 bolt..hopefully that made sense, pics below:
original site link :
http://www.rtxwheels.com/wheels/rtx/ink.aspx
the site shows a different part number for the 4 and 5 bolt..so based on the pictures above, im guessing that it wont fit
Only way to be safe is get the actual model/size/offset/and bolt pattern from the seller of the wheels and call the factory...or most reputable tire/wheel shops here in the states can test fit wheels for you...most charge a very minimal fee.
her car would use:
part number: 081117; 15x6.5 4-100/114.3 +40 73.1 or part number: 081120; 17x7.5 4-100/114.3 +42 73.1
Best-O-Luck ,
