wreck hhr repairable
It looks like both doors are high. likely hinge damage, but there could be damage in the posts, either way it goes on to a frame rack to let the lasers measure everything to insure that it goes back to square...The angle of the photo doesn't show much of the roof but the rear door looks square so probably not too much twist...If I still had a shop it might be a good buy...
Defiantly fixable. Seen a whole lot worse. Right Front and rear door, R 1/4, R fender Hood and Deck lid probably repairable. New front bumper cover and headlight. Frame pull center post probably a rocker panel. Probably Front Right suspension: upper and lower control arm and spindle. Probally more.
