100,000 mile maintenance
I am right at the 100k mark and would like to make it to 200k.
I installed new shocks and struts
Changed transmission fluid
replace front brake pads
replaced engine coolant fluid
replaced spark plugs
changed oil and all filters.
and had 4 wheel alignment.
Is there any thing else I need to do?
Welcome to the site! Seems like you have it covered,
I'd check the timing chain tensioner also to ensure it is the new style, but if it is not noisey on start up it isn't critical.
Check those LCA rear bushings and the sway bar bushings
I'm at 195,000 miles the bushing on the right is my second set of LCA GM bushings installed about 4 years ago at about 100,000 miles!
The bushing on the left is the new Moog K200792 problem solver , not a rubber bushing but a bearing
did you replace the coil packs?
I see you replaced the spark plugs but what about the coil packs. I must admit I got mine ac delco from amazon. only 24 a piece. I use all ac delco parts on my hhr 07 2 lt
hope it helps
hope it helps
i just had to replace the coil on my 2006....single unit....i was getting a P0303 along with a misfire. 98K miles...also, that MOOG lower arm/rear bearing looks great..but, unless i missed something, the MOOG page doesn't show an appliction for the HHR....maybe the cobalt ones fit..??...already replaced mine with MOOG rubber bushings awhile back..
http://www.moogproblemsolver.com/moo...ings_Sheet.pdf
Well this isn't the Aston Martin forum, so I'm sure interests vary, because the hhr is so utilitarian, love mine, but some just poke in to ask a question, and don't even come back for the answer. Doesn't matter.
