2.2 check engine light
Check engine light on: 2.2 throwing code for crankshaft position sensor. Have replaced crankshaft position sensor, camshaft position sensor, spark plugs, air filter, cleaned throttle body, & running Lucas fuel conditioner. Still throwing the same code! Help!!!!
I don't know where you got crankshaft anything out of that code. The title is "Intake camshaft position sensor performance".
The intake camshaft position senor is the one facing the grill. If that is the one you replaced there is a wire or connector problem. Trace all 3 wires from the sensor looking for breaks.
Read possible solutions
https://www.obd-codes.com/p0341
seems like a loose connection Or chafed wires
mrmarkuSS
09-29-2017 07:45 PM
jojo33
05-20-2013 01:02 PM
