2.4 timing chain interval?
My 2008 with the 2.4 has 140,000 miles on it, I'm getting no CEL since changing the cam actuators, but I'm curious as to what mileage the chain usually lasts. I don't particularly want to wait for a code to change it out. I'm not currently hearing any noises. I plan to swap it out this summer since I do not know if it has ever been changed.
I have found around 120,000 to 150,000. Mostly a stretched chain or a broken front guide and or guide bolts.
It’s much easier to just change the chains , sprockets and guides as preventative maintenance, then reconstruction of a damaged engine! Bent valves aren’t fun to change, neither are damaged pistons.
Timing chain
Had to replace timing chain both of them one for water pump was changed at around 86000 miles broken guides one price had fallen into the oil pump they had to remove oil pan to get the broken guide labor was 750.00 parts were 250.00 this was 2011 HHR with the 2.2 eng.
The only reason I can think of to pull the pan would be to check for metal fragments maybe? Dunno, I wouldn't worry about plastic either. I expect it was so the shop would have it's 'assets' covered in case of engine failure after the repair.
Guide
Guide the shop recommended taking the pan off left it up to me extra 100 bucks next time I'll know.
