2006 HHR - Fuel Level Fluctuates
Does it really matter if you are out of gas now or 2 minutes from now? You're still out of gas.
The moment that you stop moving with the engine running your MPG changes to 0. When the level is low the sloshing has a larger effect, because of the shape of the tank. If this was last century a "floating needle" might be a thing.
It's like those ambient temp readings. They don't always read correctly until you are moving at over 30 mph for 5 minutes or something. All to prevent ridiculous readings from a hot parking lot from freaking people out.
