2009 HHR Drivers Power Window not working
Hello, I have a 2009 Chevy HHR, the drivers side power window does not roll up or down. the remaining 3 do work from the drivers side. The passenger window switch does not work up or down. left rear and right rear both work from there switch. I have change the Rap relay, the power window fuse (17) i have change the power window fuse (29) i also have change the driver door switch. still the driver window with not roll up or down but from the drivers side the passenger windows works, but not the passengers switch. any and all help is greatly appreciated.
I did not see any broken wires when I pulled the door apart. The switch came from Amazon. The old switch and the new switch have the same issue.
Stupid question first: is the lock out button unlocked?
The Brown and Dark Blue (the one between Yellow & Brown) wires from the switch block go to the driver motor. The other Dark Blue wire locks the LR switch. Any chance wires got mixed up?
I am assUming you replaced the entire driver switch module.
The motor and the wires are the only items left that could affect the driver window. All of the windows are on the same fuse/relay. The wires go uninterrupted from the switch to the drive motor.
The passenger switch contacts could be bad, since it works from the driver switch.
